Jamesasd
Message 1 of 10
Bt infinity
My internet restarts 1-2 times a day I've had infinity for around 4 months what can I do? It gets so annoying internet shouldn't be restarting whenever it likes everyday
9 REPLIES 9
Sage
Sage
Message 2 of 10
Re: Bt infinity
Check your phoneline for noise, if you hear any crackling, gissing etc. report it as a line fault without mentioning broadband.
Quiet line test dial 17070 option 2.
Enter the HH5's webpage (details on card at back of HH5) and copy and paste lines 1-12 from troubleshooting helpdesk.
Jamesasd
Message 3 of 10
Re: Bt infinity
1. Product name: BT Home Hub
2. Serial number: +068543+NQ51129106
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 10/07/15
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 05:27:03
6. Data rate: 9995 / 39993
7. Maximum data rate: 23501 / 61126
8. Noise margin: 15.6 / 11.8
9. Line attenuation: 16.4 / 15.5
10. Signal attenuation: 16.3 / 15.5
11. Data sent/received: 260.4 MB / 3.8 GB
12. Broadband username:
Jamesasd
Message 4 of 10
Re: Bt infinity
Bump
Guru
Guru
Message 5 of 10
Re: Bt infinity
How was the quiet line test? as any noise, crackling, poor line can cause issues.
Do you have a Service Specific Faceplate (SSFP) master socket, or using microfilters?
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Jamesasd
Message 6 of 10
Re: Bt infinity
I'm using micro filters, with a bt socket and the quiet line test was silent so I don't know what the problem is the internet resets get very annoying with my old connection the internet never resetted
Message 7 of 10
Re: Bt infinity
can you connect to the test socket with a new filter and see if that helps
Jamesasd
Message 8 of 10
Re: Bt infinity
what is the test socket? sorry
Message 9 of 10
Re: Bt infinity
Jamesasd
Message 10 of 10
Re: Bt infinity
alright i will try that tommorow and ill get back to you, currently not at home thankyou for the advice
