Jocky1976
Message 1 of 2
Bt smart hub problem.
Hi everyone.i need help!!! Since last year I have had constant problems with the bt smart hub.i am now on my 4th one.The same thing happens every single time.they work fine for between 1-2 months then turn solid orange.I cannot factory reset as it doesn't respond.BT keep saying my line is fine,and funnily enough when I plug my old home hub 5 in,it works perfectly!! How the hell can that be?! I'm baffled.currently waiting on another hub being delivered but I know the same problem will arise eventually.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Bt smart hub problem.
@Jocky1976 That's not good at all, please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll raise this with the Hub team. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
