Djb32211
Message 1 of 3
Bt ultrafast (gfast)
Hi
How long did it take to get the correct speeds after first install of ultrafast?
Also did it take long to go from ultrafast 1 to ultrafast 2 in terms of the download and speeds updating?
2 REPLIES 2
ZooBurner
Message 2 of 3
Re: Bt ultrafast (gfast)
I opted for Ultrafast 2 directly a while ago.
Speed were there on day one, and has been a rock solid connection.
As I understand the options one and two they are the same, but option one is software limited, once the software limit is lifted it should jump right away.
imjolly
Message 3 of 3
if you have a problem with gfast then phone 08005874787
