Message 1 of 6
Buffering
Netflix, youtube etc keeps buffering all the time. I have rebooted tge router. I am on fibre 900 getting 700mb. My TV and android box are wireless. Any help apprieciated
5 REPLIES 5
Message 2 of 6
Re: Buffering
Hi @xGametekx.
Thanks for coming to the community.
Does the buffering happen on both the TV and Android box?
Are they both in the same room as the hub, or in different rooms?
Have you noticed if any other devices connected to WiFi are affected?
Debbie
Message 3 of 6
Re: Buffering
Yes buffering happens on both tv's, one in the living room and one in the bedroom. Also on android box and firestick, again front room and bedroom. I have not noticed other devices.
Message 4 of 6
Re: Buffering
Thanks for coming back to us, @xGametekx.
Has this only started recently, or has it been happening for some time?
Does the buffering happen all the time, or does it come and go?
If possible, could you try temporarily connecting one of the affected devices directly to the hub using an Ethernet cable to see whether the buffering continues?
Debbie
Message 5 of 6
Re: Buffering
The buffering continues with ethernet. Been happening about 4 weeks
Message 6 of 6
Re: Buffering
Thanks for trying that, @xGametekx.
As the buffering continues when connected directly to the hub and is affecting multiple devices, it doesn't appear to be isolated to a single device or the WiFi connection.
I'd recommend getting in touch with our customer support team so they can investigate this further for you.
Debbie
