Distinguished Guru
Distinguished Guru
Message 51 of 68
Re: Cabinet 50 Swadlincote Exchange
VM run right down Benton Rd and have done since the days of Telewest.
Message 52 of 68
The fact remains that people lobbied for it and virgin have provided it to quite a large number of houses, where there was no cabling/ducting previously, which was my original point 🙂
jamesj74
Message 53 of 68
H o w     l o n g   d o     I    h a v e     t o    w a i t ?........
"Your area is enabled for Superfast Fibre but demand is high on your cabinet right now. This means you may not be able to order fibre today but we're working to increase capacity. Please check back for an update."
It's been saying that for 6 months...  Mean time I'm stuck with super slow ADSL (1.56Mb).
There has to be a beter way that this surely!?!  I've only been waiting a year...
Message 54 of 68
Have you been checking every day? If you're in a high demand area then as soon as capacity becomes available, it might be being swallowed up. However, it may well be that your cabinet is completely full with no room for additional line cards. If this is the case, Openreach will need to install a second fibre cabinet to increase capacity.
jamesj74
Message 55 of 68
Yes - I check every day.  BT executive support is also supposed to email me progress reports, but I hear little from them.  It seems OpenReach is a law unto itself.
Message 56 of 68
Well, it is their network. So they can do what they want.
jamesj74
Message 57 of 68
Yes - with no customer facing element they are a rule unto themselves and answerable to no one...  I think you pretty much summed up my problem in one sentence.  How about I start supergluing the padlock on their compound gates in Overseal until they fix this?
jamesj74
Message 58 of 68
"affirmative action"
Message 59 of 68
Go ahead, but be prepared for Openreach to take legal action if you're caught. It would probably be classed as criminal damage.
jamesj74
Message 60 of 68
At least then I might actually get to speak to someone from openreach...
