Huskydog
Message 71 of 79
Re: Cabinet 50 Swadlincote Exchange
the data is below and it says i have FTTP on demand but not sure how to order or how much it would be !!
Annotation 2019-07-30 101504.jpgthats all the data
Message 72 of 79
FTTP on Demand is for business use just now and is expensive
from checker you have FTTC with speeds well within expected range
Carlusha
Message 73 of 79
Check here:
OpenReach fibre checker
Select the FTTP option.
Huskydog
Message 74 of 79
thanks but was hoping bt maybe upgrading to G fast
Sage
Sage
Message 75 of 79
You wouldn't be able to upgrade to G.Fast. You are too far away from the cab.
Message 76 of 79
there is nothing but FTTC showing at present but just keep checking you never know when it might change
this for info not sure how up to date
https://www.openreach.co.uk/orpg/home/products/pricing/loadProductPriceDetails.do?data=0WyIM7tTGGguc...
Huskydog
Message 77 of 79
thanks
Huskydog
Message 78 of 79
thanks for your help only FTTC unfortunately
Carlusha
Message 79 of 79
If you complete the form I linked above, Openreach will advise you should the situation change.
Again :
https://www.openreach.com/fibre-broadband/fibre-first#FibrecheckerX
