Ronnie82
Message 21 of 24
Re: Cabinet change
I havent forgotten... i'm at work, need to be home to do so
pompey1898
Expert
Message 22 of 24
Re: Cabinet change
Have you contacted your local BDUK scheme to see if there any plans that maybe beneficial to you ?
Starwire
Message 23 of 24
Re: Cabinet change
Openreach will only move you onto a different cabinet if it was missed out of a planned cabinet migration in error.
So if it was planned for your line to be routed to this new PCP and it wasn’t for then Openreach will reroute it, providing its technically possible.
If it wasn’t planned to be migrated though they won’t because if they do it for you they’ll have do to it for Dave down the road, do it for him and they’ll have to do it for his neighbour John, then John’s mate across the road and so on and so on.
Ronnie82
Message 24 of 24
Re: Cabinet change
This is as I thought, thanks for the reply.
