Dale8787
Newbie
Message 1 of 3
Cable rquired for Infinity
My master socket in in my loft with feed from street which is overhead.  From my master socket, I have several sockets wired with Cat3 cable.  My current router is connected to one of these.
My question is: What would the route for the Infinity cable be to my master socket? Would it also be overhead? Also would my router location have to change or would it continue to be at current location connected to the master socket by Cat3 cable?
Any advice would be appreciated as I do not want to ‘sign up’ only to find that cabling would be an issue or that Open Reach would not run the cable in an acceptable maner.
2 REPLIES 2
dombullion
Message 2 of 3
Re: Cable rquired for Infinity
Hi Dale8787,
THe engineer can run an extension kit up to 3 metres I believe so that you can have your Hub further away from your main socket.
I think this is correct but i'm sure someone will correct me if I am wrong.
Dominic
Message 3 of 3
It is up to 30 meters.
You could always ask the engineer to move your master socket to a better location.
