Message 1 of 11
Can I get Superfast Fibre & If not how would I go about getting it?
Hi,
Please could someone help me put me in the right direction here are my internet results I can provide.
Am I able to get Superfast Fibre Broadband? If not which ways can I go to help getting it.
Here are my results:
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 0176 on Exchange HEYWOOD is served by Cabinet 5
Featured ProductsDownstream Line Rate(Mbps)Upstream Line DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsVDSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean) 42.7 30 7.7 5.4 26.2 Available Available --
VDSL Range B (Impacted) 41.3 25 7.6 5 20 Available Available --
FTTP on Demand 330 30 -- Available -- --
WBC ADSL 2+ Up to 12 -- 7 to 17 Available -- --
WBC ADSL 2+ Annex M Up to 12 Up to 1 7 to 17 Available -- --
ADSL Max Up to 8 -- 7 to 8 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
Max Observed Downstream Speed (Mbps) 33.55
Max Upstream Observed Speed (Mbps) 4.76
Observed Date 2019-11-06
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 29-10-2019
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market B Exchange.
For VDSL or G.fast Ranges A and B, the term "Clean" relates to a line which is free from any wiring issues (e.g. Bridge Taps) and/or Copper line conditions, and the term "Impacted" relates to a line which may have wiring issues (e.g. Bridge Taps) and/or Copper line conditions.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 30-Nov-2012; the Formal Retirement date for IPstream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Note: If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service.
Thank you for your interest.
10 REPLIES 10
Message 2 of 11
Re: Can I get Superfast Fibre & If not how would I go about getting it?
please delete your phone number
from the checker you are already on an FTTC connection
Message 3 of 11
Deleted
Message 4 of 11
When i'm wanting to Upgrade my internet Ultrafast broadband say's its unavailable would this be correct?
Sage
Message 5 of 11
Correct, you cannot get Ultrafast. Your question was about Superfast which as pointed out you already have.
Message 6 of 11
Ultrafast is not available to you.
Message 7 of 11
How would I go about getting also please could somebody remove this post as I mean ultrafast broadband
Message 8 of 11
You can't, it is not available.
Message 9 of 11
as already said ultrafast broadband is not available to you
Message 10 of 11
Its not available from your cabinet, not all cabinets have the extra "pod" on the side. Your post can stay here, as the answer has been reached anyway.
