texxaco
Message 1 of 8
Can I use a ASUS DSL-AC68U modem Router on FTTP?
Evening all,
I have just had BT FTTP installed and found the BTHub 6 to be unreliable hence my question. Can I use my Asus DSL -AC68U ADSL/VDLS modem router in its place?
I have searched this forum and others with little success.  The ASUS DSL-AC68U doesnt have a dedicated WAN port but  Asus in their wisdonm allows you to specify a LAN port to set as a WAN port, which I have done successfully. Sadly this is as far as i have been able to get.
Should anyone be able to assit I would be forever grateful.
Many thanks   Pete
7 REPLIES 7
TimCurtis
Recognised Expert
Message 2 of 8
Re: Can I use a ASUS DSL-AC68U modem Router on FTTP?
You should be able to. Here's a recent thread for the AC56U to work with the OpenReach modem:- Using Asus DSL modem/Router with FTTH/FTTP
Also found this "A quick search for 'use ASUS DSL-AC68U as router only' turned up a few results.  Quote from one forum post:- ">Go at wan > dual wan (don't enable it) and set primary wan to Ethernet LAN & set 1 of the 4 LAN ports (example LAN 4) ...>"
texxaco
Message 3 of 8
Thanks Tim, I did as advised, the router says its connected yet I have no Internet access. We I try to load a page I get a BT Wholesale service information page pop up.
licquorice
Message 4 of 8
That suggests an account problem rather than a technical problem. If you can reach the Wholesale information page you have the correct settings.
texxaco
Message 5 of 8
I wish I could share the page to allow you to see the message. The message doesn't really provide me with a place to start looking. I know my line is still up as I hook up the HH6 and internet.
The message starts with" You have been connected to this page due to one of the follwing reasons " ring any bell?
Cheers
Pete
licquorice
Message 6 of 8
If the HH works its an authentication problem with the ASUS. With FTTC you authenticate against the phone line and thus there is a generic PPP username of bthomehub@btbroadband.com. With FTTP, I thought the ONT did the authentication so username on the router should be irrelevant. Counter intuitively, you could try leaving the username and password blank on the ASUS.
texxaco
Message 7 of 8
Sorted it, the bthomehub @ BT broadband. Come and BT is required for FTTP. School boy error on my part, an extra d got lodged in after after broad. Sorted now and so very pleased to get rid of the HH6. Cheers for all your help everyone, one happy puppy here
licquorice
Message 8 of 8
Good result and thanks for confirming the generic PPP authentication is still required.
