Juthely
Message 1 of 12
Can a mod please check to see if my exchange is having congestion issues?
Hi all,
I'm having all the symptoms of congestion here, but I'm struggling to get this confirmed via the telephone. We've got a quiet line with perfect speeds througout the day, but dropping massively of an evening. 2 Openreach engineers have confirmed that all wiring is perfect in our home.
I'm on Exchange WOODGATE , Cabinet 30 🙂
Thanks in advance!
11 REPLIES 11
imjolly
Message 2 of 12
Re: Can a mod please check to see if my exchange is having congestion issues?
post some btspeedtster results with ethernet conenction - first when ok off peak and last peak when poor to illustrate your problem
Juthely
Message 3 of 12
Here are two speedtests from the BT test site, both taken whilst there is no other traffic, and with an ethernet connection. One at 18:30, and another at 20:45. The problems typically begin around 19:00-19:30 and it's all back to normal at 22:30ish! These results aren't too bad to be honest, it often drops into single digits, making streaming very difficult.
PaddyB
Moderator
Moderator
Message 4 of 12
Hi @Juthely,
I've had a look at it does look like there is a congestion issue at your exchange. That is affecting your speeds during peak times. Please can you send me in your details using the "Contact The Mods" link found in my profile. I'll be able to take a look to see if anything can be done to improve your speeds.
PaddyB
Juthely
Message 5 of 12
Hi @PaddyB,
Thank you for the confirmation! I've sent the details as requested.
Thanks,
Lee
PaddyB
Moderator
Moderator
Message 6 of 12
Hi @Juthely,
Thank you for sending in your details. I gave your mobile number a quick call, I'm sorry I didn't get speaking to you today.
I've reported a fault through to BT Wholesale and I should have an update for you on Monday. I'll give you a call as soon as I know more.
PaddyB
PaddyB
Moderator
Moderator
Message 7 of 12
Hi @Juthely,
I got word back from BT Wholesale. They are making a few changes to your circuit and you should see an improvement over the next 48 hours.
PaddyB
Juthely
Message 8 of 12
Hi @PaddyB
Thank you for chasing this, that's great! I'll keep an eye on it over the next few days and report back.
Cheers,
Lee
PaddyB
Moderator
Moderator
Message 9 of 12
Hi @Juthely,
I've got confirmation from BT Wholesale that they've completed their work and this should see your speeds increase. Please can you retest your speeds using the link http://www.speedtest.btwholesale.com/ and post back the results?
PaddyB
Juthely
Message 10 of 12
Hi @PaddyB
I'm working away over the next couple of days, but should be back Friday. I'll certainly post some results. Fingers crossed!
Thanks for your help
Lee
