Venomx
Expert
Message 1 of 7
Can i get FTTP ?
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Re: Can i get FTTP ?
Yes, if you want to pay.
FTTP on demand cost
Prices for 2018
imjolly
Message 3 of 7
FTTPoD is not the same as FTTP
cost of FTTPoD https://www.openreach.co.uk/orpg/home/products/pricing/loadProductPriceDetails.do?data=0WyIM7tTGGguc...
Venomx
Expert
Message 4 of 7
Theres a lot of info on that page, but to summarise, the minimum per month is £92 right ?
Venomx
Expert
Message 5 of 7
What is the difference ?
gg30340
Message 6 of 7
You also have survey fees and installation costs as per the distance they have to lay the fibre.
FTTP on Demand is a bespoke fibre solution for your premises. It is primarily aimed at businesses.
FTTP is the residential Fibre to the Premises and is usually only available if there is no FTTC Fibre to the Cabinet available due to distance from the cabinet.
You are able to get FTTC so you will not be offered FTTP.
Venomx
Expert
Message 7 of 7
Great, thanks 🙂
