Saffiny
Message 1 of 3
Can someone explain why, since around, 15th of January my internet disconnects in the early morning?
Ever since around the 15th, my "BT Hub 6A" will basically drop the signal ALWAYS (without fail) between the hours of 3am and 9am, i have had almost a whole month to track this, so it's not random, my internet then stays up from whenever it happens, for upto 13 hours, until it drops again, heres my current router stats and logs.
Product name:
BT Hub 6A
Serial number:
+084316+NQ83177242
Firmware version:
SG4B1000B540
Firmware updated:
13-Dec-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 8 Minutes 23 Seconds
Data rate:
20.00 Mbps / 75.05 Mbps
Maximum data rate:
27135 / 77128
Noise margin:
15.4 dB / 3.3 dB
Line attenuation:
15.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
176133 MB Uploaded / 147793 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-X6C8
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-X6C8-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A8:9A:93:43:2C:FF
Software variant:
Boot loader:
9.2.0
2 REPLIES 2
Saffiny
Message 2 of 3
Re: Can someone explain why, since around, 15th of January my internet disconnects in the early morn
 Log of the said event.
Time and date
Message
Selected:  ALL
03:00:43, 05 Feb.
ppp1: Allocated prefix = 2a00:23c5:6d84:ff00::/56 (valid time = 240000000 / preferred time = 0)
03:00:43, 05 Feb.
ppp1Smiley TonguePP: PPP INFO
03:00:43, 05 Feb.
BR_LAN:LAN Router Advertisement Setting Updated : M_flag = 0, O_flag = 1
03:00:43, 05 Feb.
BR_LAN:The LAN DHCPv6 Server is active
03:00:42, 05 Feb.
BR_LAN:The LAN DHCPv6 Server is inactive
03:00:42, 05 Feb.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
03:00:42, 05 Feb.
BR_LAN: Revoked prefix = 2a00:23c5:6d84:ff00::/64 (valid time = 240000000 / preferred time = 0)
03:00:42, 05 Feb.
: Revoked prefix = 2a00:23c5:6d84:ff01::/64 (valid time = 240000000 / preferred time = 0)
03:00:42, 05 Feb.
: Revoked prefix = 2a00:23c5:6d84:ff00::/56 (valid time = 240000000 / preferred time = 0)
03:00:42, 05 Feb.
03:00:41, 05 Feb.
pppSmiley TonguePP: IPCP_NAK
03:00:41, 05 Feb.
pppSmiley TonguePP: CHAP_SUCCESS
03:00:41, 05 Feb.
pppSmiley TonguePP: CHAP_RESPONSE
03:00:41, 05 Feb.
pppSmiley TonguePP: LCP_GOOD_ACK
03:00:41, 05 Feb.
pppSmiley TonguePP: LCP_REQUEST
03:00:41, 05 Feb.
Smiley TonguePPoE error: timeout
03:00:38, 05 Feb.
:HTTP UserAdmin login from 192.168.1.68 successfully
03:00:32, 05 Feb.
:HTTP UserBasic login from 192.168.1.68 successfully
03:00:32, 05 Feb.
03:00:21, 05 Feb.
03:00:07, 05 Feb.
ptm0.101:VLAN VLAN_DATA connected
03:00:07, 05 Feb.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
03:00:07, 05 Feb.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
03:00:07, 05 Feb.
dsl:VDSL link Up: Down Rate=73715Kbps, Up Rate=19999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
03:00:02, 05 Feb.
:The LAN DHCP Server is active
02:59:57, 05 Feb.
:The LAN DHCP Server is inactive
02:59:57, 05 Feb.
BR_LAN:The DHCP options that are offered by the device (id:2): DiscoverOptions: 53,61,57,60,12,55 | DiscoverOption55: 1,3,6,15,26,28,51,58,59,43 | RequestOptions: 53,61,50,54,57,60,12,55 | RequestOption55: 1,3,6,15,26,28,51,58,59,43 | HostName: android-9950ee79cb24a6e8 | VendorId: android-dhcp-7.1.1
02:59:57, 05 Feb.
Smiley Very HappyHCP Confirmation of Request
02:59:50, 05 Feb.
:VLAN VLAN_DATA disconnected
02:59:50, 05 Feb.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
02:59:50, 05 Feb.
wl0:A WiFi device <40:40:A7:B2:9B:C0> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
02:59:50, 05 Feb.
02:59:50, 05 Feb.
02:59:45, 05 Feb.
ppp1:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
02:59:45, 05 Feb.
ppp1:The DYN ROUTE [81.139.57.100/32 gw ] is deleted
02:59:45, 05 Feb.
ppp1:The DYN ROUTE [81.139.56.100/32 gw ] is deleted
02:59:44, 05 Feb.
02:59:44, 05 Feb.
wl0Smiley Very Happyevice <40:40:A7:B2:9B:C0> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
02:59:43, 05 Feb.
02:59:43, 05 Feb.
02:59:42, 05 Feb.
02:59:42, 05 Feb.
02:59:42, 05 Feb.
ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
02:59:42, 05 Feb.
02:59:42, 05 Feb.
02:59:42, 05 Feb.
BR_LAN: Revoked prefix = 2a00:23c5:6d84:ff00::/64 (valid time = 2026291200 / preferred time = 2026291200)
02:59:42, 05 Feb.
ppp1: Revoked prefix = 2a00:23c5:6d84:ff01::/64 (valid time = 2026291200 / preferred time = 2026291200)
02:59:42, 05 Feb.
ppp1: Revoked prefix = 2a00:23c5:6d84:ff00::/56 (valid time = 2026291200 / preferred time = 2026291200)
02:59:40, 05 Feb.
dsl:VDSL Link Down: duration was 79517 seconds
Saffiny
Message 3 of 3
is my HH6 dying or what? i've only had it since november, the reason i ask is because ive searched around and people seem to have so many issues with BT routers
