Hi all. I wonder if someone can help me with this? I've seen similar e-mails with other users having a similar/the same problem so hopefully I can get in touch with someone who can sort this out.
I desperately want to order Fibre - All of my neighbours at even numbers seem to be able to order (some already have it). Us with odd numbers don't seem to be able to order. It looks like we are all connected to the same cabinet (BT systems confirm this) so I am thinking database error?? I have also completed and sent a form to Openreach but no response as of yet.
Please can someone point me in the right direction as to how I can get this resolved?
Hi @bmffan Welcome to the forum and thanks for your enquiry about fibre broadband.
Do you have an active phone line with BT at your address? If so please can you put your phone number into the Broadband Availabilty Checker and post the results.
Please remember to remove your phone number before posting the results.
Cheers
John
Hi. Thanks for getting back to me. Yes, I do have an active phone line. Here is the results:
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings Availability Date Premise environmentStatus
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage. This line is on a Market A Exchange. |
Hi. Thanks for getting back to me. Yes, I do have an active phone line and here are the results:
And this is the result of the house directly opposite me :
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability DateFTTP Install ProcessADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Other Offerings Availability Date
Our records show the following FTTP network service information for these premises:- Single Dwelling Unit Residential UG Feed Not Evaluated. For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage. This line is on a Market A Exchange. |
from the results and codelookup cabinet 2 is not fibre enabled cab 3 was enabled in april 2018 maybe your neighbours are on that cab
edit your neighbours have access to FTTP which has nothing to do with the cabinet
Ok, thanks for this. What would be the likely reason do you know for my neighbors (including the house directly opposite me) to have access to FTTP and I wouldn't? Is there anyway this can be resolved?
have you noticed any openreach work being done on your telephone pole? I would expect work and may black box on neighbours
Hi. We do not have telephone poles here - It's a new build estate.
ok then as new build do you have something like this in your home
