ross82
Message 1 of 3
Can’t run speed test
Full Fibre installed today with Smart Hub. Minimum download speed meant to be 455 Mbps. Speed test.net said 300 Mbps at about 5pm. Then 40 Mbps by 7pm. When I try to test the speed in the BT app I get a message saying it can’t run a test. Any advice?
2 REPLIES 2
pippincp
Message 2 of 3
Re: Can’t run speed test
You cannot run that speed test app on FTTP. Use this. https://fast.com/en/gb/
ross82
Message 3 of 3
Thanks, feel like BT should make that clearer.
