09-03-2018 10h41 - edited 09-03-2018 10h44
Solved! Go to Solution.
09-03-2018 10h47 - edited 09-03-2018 10h48
Your router stats look fine. you may get a couple more Mb if/when G.Inp gets enabled on your line.
on 09-03-2018 11h08
09-03-2018 11h58 - edited 09-03-2018 12h05
Simple explanation HERE.
Edit : Easy way to know if it's enabled, your noise margin will drop to around 3dB.
