Showofdeth
Message 1 of 4
Can these router stats be improved upon or are they about as good as I can expect?
  • Not complaining, just asking. Not going to lie though, i was hoping actual download speed would be a little better than 69Mb/s which I'm currently getting on multiple speed test apps and sites.
3 REPLIES 3
pippincp
Message 2 of 4
Re: Can these router stats be improved upon or are they about as good as I can expect?
Your router stats look fine. you may get a couple more Mb if/when G.Inp gets enabled on your line.
Showofdeth
Message 3 of 4
What's G.Inp when it's at home?
pippincp
Message 4 of 4
Simple explanation HERE.
Edit : Easy way to know if it's enabled, your noise margin will drop to around 3dB.
