Jwalsh
Message 11 of 12
Re: Canford Cliffs Cabinet 9 Query
Presumably you mean the following:
Data Rate 4.56 Mbps/18.093
Max Data Rate 4.546 Mbps/20.241
Keith_Beddoe
Message 12 of 12
Yes, but you are at the bottom end of the expected range, which suggest an issue with your internal phone wiring. Moving to BT Business is not going to change that.
Do you have any other phone sockets that may have been connected to your phone line before the master socket, as these will affect your speed?
Some older properties were wired with extensions originating from a connection block. Here is a typical example from my website pages.
