Message 1 of 3
Cannot connect my PC to BT Hub 5
Hi,
My PC was happily connected to my BT Hub 5 via the ethernet cable. Unfortunately, since my cleaner cleaned the area where my hub is my PC cannot connect to the hub. I can connect my phone to the hub via WiFi but I cannot connect my PC to the hub either by ethernet or WiFi.
I've restarted it, replugged the cables etc but still nothing. Can anyone suggest anything?
2 REPLIES 2
Message 2 of 3
Re: Cannot connect my PC to BT Hub 5
Try another Ethernet cable
Message 3 of 3
Have you by any chance plugged the Ethernet cable into the red WAN port rather than a LAN port?
