smartsmart6
Message 11 of 13
Re: Change network username and password on by business hub 6
Hi network user name and password
smartsmart6
Message 12 of 13
Yes pressed the button with a paper clip for 25/30 seconds to reset it
licquorice
Message 13 of 13
If you are managing to connect to the internet with those credentials I guess for FTTP the authentication is against your ONT serial number rather than phone number as it is for FTTC.
If the hub is connecting and working, there is no problem in leaving the credentials, they would have been used for the original owner to connect to the internet and will present no security risk to you.
