mychips
Message 1 of 7
Changed Router now BT TV not working
I have upadted my modem to a Draytek Vigor 130 and have a Draytek 2820n router which accesses the internet great and performace is fine with my Infinity2 broadband. The only real issue is that the BT TV subscribtion channels are not working, i have ticked both the IGMP Snooping and Proxy for WAN2 as that is where the Modem is connected.
are there any ideas its driving me nuts?
6 REPLIES 6
licquorice
Message 2 of 7
Re: Changed Router now BT TV not working
Try enabling IGMP snooping but disabling IGMP proxy.
mychips
Message 3 of 7
not made any difference im afraid.
I can see the BTTV box on the DHCP table
Liam_
Recognised Expert
Message 4 of 7
You could have a look here and see if the info helps.
https://www.draytek.co.uk/support/guides/kb-igmp-proxy
Unfortunately you will need to register first to get access.
mychips
Message 5 of 7
Thank you for the link but i have already looked at the Draytek info, I must be missing a trick or something as i can do everthing else fine.
TimCurtis
Recognised Expert
Message 6 of 7
licquorice
Message 7 of 7
Just re-read your original post, I think you need to enable igmp snooping on the LAN port the tv box is connected to not the WAN port.
