midlife
Message 1 of 4
Checking speed with BT Wholesale performance test
when I got the original fibre to the premises I was told to use the BTW performance test which was great and showed the correct speed. I have now gone onto ultrafast which means I should get a minimum of 100mb but stated 150mb. when they transferred across to ultra it showed 338mb and then 974mb which didn't make sense, its now shows 16mb and 18mb which is obviously wrong as when I check on speedtest it is showing an average of about 125mb.
what BT speed test should be used for ultrafast?
thanks
Graham
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: Checking speed with BT Wholesale performance test
Hi @midlife you should use the speed tester on the MyBT site or MyBT App to check your speed.
midlife
Message 3 of 4
thank you
was told to use the wholesale one before
will now use the other bt system
NeilO
Moderator
Moderator
Message 4 of 4
@midlife no problem, I was happy to help 😀
