LiamS
Message 51 of 57
Re: Chiswick Exchange
@NeilOwrote:
@LiamS I appreciate how frustrating this must be for you. I have a feeling things won't improve much until they physically install the new infrastructure to increase capacity.
If you can capture that result, I'll get back on to them. The BT wholesale office I need to report this to have just closed for the weekend but I'll get on to them on Monday.
Willl do thanks again Neil if you can get them to put me back on to the SVLAN i was on before would be great. Then i'll keep an eye on it and wait until they put new infrastructure in to improve it. Until then i'll give the results tonight and wait till Monday.  Smiley Happy
Moderator
Moderator
Message 52 of 57
Thanks @LiamS I'll ask them to do that on Monday.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
LiamS
Message 53 of 57
Thanks again @NeilO you've been of great help really appreciate this Smiley Happy
LiamS
Message 54 of 57
Hi @NeilO Here's the peak times speeds 8:10pm 23/03/2018
BT Smarthub Stats
Product name:
BT Hub 6A
Serial number:
+084319+NQ63056095
Firmware version:
SG4B1000B522
Firmware updated:
28-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 22 Hours 55 Minutes 9 Seconds
Data rate:
20.00 Mbps / 74.00 Mbps
Maximum data rate:
29045 / 85777
Noise margin:
15.3 dB / 8.8 dB
Line attenuation:
12 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
ADSL Checker
BT Wholesale Test
Moderator
Moderator
Message 55 of 57
Thanks @LiamS. Don't do any further tests as that one will be enough, I'll get back on to Wholesale on Monday.
Kudos”Kudos”
LiamS
Message 56 of 57
Won't do thanks again @NeilO absolute legend Smiley Happy
LiamS
Message 57 of 57
Hi Neil can you please let them know today. Cause I have a lot to do today and need this to be done Thank You. 😊 👍
LiamS
