Moderator
Moderator
Message 21 of 29
Re: Congestion on infinity 1 line
Hi @SteveTheChef
Cheers for the update.
Run one test for me on the BT wholesale speed test site I will be in touch shortly.
Stuart
Message 22 of 29
test 30-12-17.pngThanks for the call, I thought it would drop towards the evening. here is what i got just now
will keep monitoring it
Moderator
Moderator
Message 23 of 29
Hi @SteveTheChef
I just ran the tests on my side to I can see the result on there.
I will need to run this past our suppliers again as the first fix hasn't sorted it.
They arent available now until Tuesday, would you be available to take a call Tuesday evening?
Stuart
Message 24 of 29
Hi Stuart
I’m away on business next week until Friday, I will be free Friday evening and the weekend if that’s any good
Moderator
Moderator
Message 25 of 29
Hi @SteveTheChef
I'll be out of office Friday evening but I can call you on the Saturday if that works ok.
I'll do my best to keep you updated of any changes in the meantime, so you're aware of whats happening.
Cheers
Stuart
Message 26 of 29
Yes Saturday is fine, gives me a chance then to run a speed test at peak times in the evening on Friday before we speak then
Message 27 of 29
Hello  @StuartH
Just a quick update before our chat tomorrow. I dont know if you have spoken with bt wholesale since our last conversation. Just ran a speedtest and dl speeds are still slow.
I will post a screenshot here for you and bt wholesale can see my last speedtest anyway.
cheers
Steve
test 5th Jan 18
Message 28 of 29
Hi Stuart
Sorry I missed your call, hopefully your conversation with the suppliers today will have a resolution tomorrow
Steve
Moderator
Moderator
Message 29 of 29
Hi @SteveTheChef
Thanks for taking my call today, it took a bit of time but now that the infrastructure work has been completed, I am pleased to hear the speeds have improved.
Should you need help again please post back in the community.
Cheers
Stuart
