Distinguished Guru
Message 11 of 13
Re: Connecting Modem to Router
Four pairs of wires. So eight connections.
Blue/white
Green/white
Orange/white
Brown/white
Distinguished Guru
Message 12 of 13
gigabit then.
If not, I'll try again 🙂
Guru
Message 13 of 13
I agree with the others that a single cable will be more straightforward. However, unlike VDSL, ethernet is pretty forgiving, so you are very unlikely to to have any loss of speed from the three cable solution. It's really a matter of which your find neatest for your environment.
Even thought it is a gigabit cable you showed, the modem to HomeHub connection is only 100Mbps.
