MightyMan
Message 1 of 7
Connection Problems
Hi There I Have Got Bt Hub 5 And For Some Reason  My Connection Keeps On Dropping Ive Noticed A Few  Issuse On Bt Hub Log  this is the log from when it disconnected it Self Can Anybody Help Me With This Issue
20:16:29, 29 Apr.( 78.360000) Lease for IP 192.168.1.92 renewed by host udhcpc1-​21-​1-​78-​bd-​bc-​87-​c7-​3c (MAC 78:bd:bc:87:c7:3c). Lease duration: 1440 min
20:16:29, 29 Apr.( 78.360000) Device connected: Hostname: udhcpc1-​21-​1-​78-​bd-​bc-​87-​c7-​3c IP: 192.168.1.92 MAC: 78:bd:bc:87:c7:3c Lease time: 1440 min. Link rate: 81.5 Mbps
20:16:29, 29 Apr.( 78.130000) Lease requested
20:16:26, 29 Apr.( 74.900000) CWMP: session closed due to error: No response
20:16:18, 29 Apr.( 66.900000) Lease for IP 192.168.1.92 renewed by host udhcpc1-​21-​1-​78-​bd-​bc-​87-​c7-​3c (MAC 78:bd:bc:87:c7:3c). Lease duration: 1440 min
20:16:18, 29 Apr.( 66.900000) Device connected: Hostname: udhcpc1-​21-​1-​78-​bd-​bc-​87-​c7-​3c IP: 192.168.1.92 MAC: 78:bd:bc:87:c7:3c Lease time: 1440 min. Link rate: 6.0 Mbps
20:16:18, 29 Apr.ath00: STA ac:63:be:2d:b0:c5 IEEE 802.11: Client disassociated
20:16:17, 29 Apr.( 66.670000) Lease requested
20:16:17, 29 Apr.ath00: STA ac:63:be:2d:b0:c5 IEEE 802.11: Client associated
20:16:17, 29 Apr.ath10: STA 78:bd:bc:87:c7:3c IEEE 802.11: Client associated
20:16:17, 29 Apr.ath00: STA a0:1d:48:ec:0e:2c IEEE 802.11: Client associated
20:16:10, 29 Apr.( 58.990000) Device disconnected: Hostname: amazon-​f7bf0ce08 IP: 192.168.1.100 MAC: 88:71:e5:0b:34:3b
20:16:10, 29 Apr.( 58.990000) Device disconnected: Hostname: amazon-​647acb78c IP: 192.168.1.99 MAC: ac:63:be:2d:b0:c5
20:16:10, 29 Apr.( 58.990000) Device disconnected: Hostname: android-​d1e67862c3ce3433 IP: 192.168.1.96 MAC: 20:55:31:dd:80:69
20:16:10, 29 Apr.( 58.990000) Device disconnected: Hostname: android-​a3101eccb5292032 IP: 192.168.1.93 MAC: 84:2e:27:ed:81:94
20:16:10, 29 Apr.( 58.980000) Lease for IP 192.168.1.70 renewed by host Mattys-​PC (MAC c8:0a:a9:9f:6f:ac). Lease duration: 1440 min
20:16:10, 29 Apr.( 58.980000) Device connected: Hostname: Mattys-​PC IP: 192.168.1.70 MAC: c8:0a:a9:9f:6f:ac Lease time: 1440 min. Link rate: 1000.0 Mbps
20:16:10, 29 Apr.( 58.770000) Lease requested
20:16:02, 29 Apr.( 51.720000) Device disconnected: Hostname: amazon-​f7bf0ce08 IP: 192.168.1.100 MAC: 88:71:e5:0b:34:3b
20:16:02, 29 Apr.( 51.590000) Device disconnected: Hostname: amazon-​647acb78c IP: 192.168.1.99 MAC: ac:63:be:2d:b0:c5
20:16:02, 29 Apr.( 51.580000) Device disconnected: Hostname: android-​d1e67862c3ce3433 IP: 192.168.1.96 MAC: 20:55:31:dd:80:69
20:16:02, 29 Apr.( 51.560000) Device disconnected: Hostname: android-​a3101eccb5292032 IP: 192.168.1.93 MAC: 84:2e:27:ed:81:94
20:16:02, 29 Apr.( 51.550000) Device disconnected: Hostname: udhcpc1-​21-​1-​78-​bd-​bc-​87-​c7-​3c IP: 192.168.1.92 MAC: 78:bd:bc:87:c7:3c
20:16:02, 29 Apr.( 51.540000) Device disconnected: Hostname: Unknown-​c8-​02-​10-​0d-​a6-​db IP: 192.168.1.85 MAC: c8:02:10:0d:a6:db
20:16:02, 29 Apr.( 51.530000) Device disconnected: Hostname: udhcp-​1-​2-​1-​04-​46-​65-​67-​c3-​84 IP: 192.168.1.76 MAC: 04:46:65:67:c3:84
20:16:02, 29 Apr.( 51.520000) Device disconnected: Hostname: Mattys-​Ipod IP: 192.168.1.74 MAC: 8c:7b:9d:c5:07:63
20:16:02, 29 Apr.( 51.400000) Lease for IP 192.168.1.70 renewed by host Mattys-​PC (MAC c8:0a:a9:9f:6f:ac). Lease duration: 1440 min
20:16:02, 29 Apr.( 51.400000) Device connected: Hostname: Mattys-​PC IP: 192.168.1.70 MAC: c8:0a:a9:9f:6f:ac Lease time: 1440 min. Link rate: 1000.0 Mbps
20:16:02, 29 Apr.( 51.130000) Lease requested
20:16:00, 29 Apr.( 49.390000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
20:16:00, 29 Apr.( 49.380000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
20:15:59, 29 Apr.( 48.590000) CWMP: Initializing transaction for event code 1 BOOT
20:15:55, 29 Apr.( 44.580000) WiFi auto selected channel 44
20:15:55, 29 Apr.( 44.580000) 36-​93::40-​93::44-​94::48-​92::52-​92::56-​92::60-​92::64-​91::100-​90::104-​93::108-​94::112-​93::116-​93::120-​94::124-​95::128-​96
20:15:55, 29 Apr.( 44.570000) 5 GHz Wireless: Rescan, Reason: 'Power-​up'
6 REPLIES 6
Message 2 of 7
Re: Connection Problems
@MightyMan
That just looks like wireless disconnects, are Ethernet devices affected, and does the light on the home hub change colour?
MightyMan
Message 3 of 7
Light on hub goes to green then flashes red and stays red then goes to blue my computer is connected to hub via Ethernet
Message 4 of 7
@MightyMan
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
MightyMan
Message 5 of 7
Line is quite on linetest
MightyMan
Message 6 of 7
I had a simular problem with bt home hub 2 it was suggested it was a high restance joint the problem
Message 7 of 7
It could be, you need to listen to the line when it drops out, to see if you can hear any crackle, as a high resistance joint will cause that.
