Alkalidum
Message 1 of 23
Connection dropped the DNS server isn't responding
My connection was working fine a couple of hours ago, I was watching a YouTube video then it suddenly cut out and hasn't reconnected for a few hours now. Checked the service status of my area and it says everything is working fine.
22 REPLIES 22
Message 2 of 23
Re: Connection dropped the DNS server isn't responding
@Alkalidum
Is your phone line working, can you get dial tone?
Alkalidum
Message 3 of 23
Yeah phone line seems fine.
Message 4 of 23
Which BT home huib do you have?
Alkalidum
Message 5 of 23
BT smart hub type A.
Message 6 of 23
What colour is the light on the front?
Alkalidum
Message 7 of 23
Blue, it's been blue all day but the Internet icon on the windows task bar at the bottom right of the screen has had the little yellow exclamation mark which keeps appearing and dissappearing. I've also tried turning the hub off and back.on again.
Message 8 of 23
First flush any old invalid DNS entries.
If its a Windows computer you are using, then type this at the command prompt
ipconfig /flushdns
Is the computer connected to the home hub using wireless or Ethernet connection?
If its wireless, then try using a direct Ethernet cable connection.
Message 9 of 23
deleted
Alkalidum
Message 10 of 23
OK successfully flushed the DNS Resolver Catch. It's connected directly by Ethernet cable.
