Message 1 of 5
Connection dropping and low speeds
Over the last week or so the broadband is dropping out every hour or so, and the download speeds appear to be slower at some times. For example Youtube autoplay will be set on 360p and randomly change back to 720/1080p
I've tried the troubleshooter which indicates no problems as well as live chat who said no problems detected (even when it had dropped out a few mins before)
4 REPLIES 4
Message 2 of 5
Re: Connection dropping and low speeds
please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 5
I called with the landline and there was a dull hum nothing too noticeable, I'm not sure exactly what stats you want from the event log or information:
Information:
Product name:
BT Hub 6AFirmware version:
SG4B1000E020
Firmware updated:
24-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 0 Hours 5 Minutes 39 Seconds
Data rate:
7.25 Mbps / 41.31 Mbps
Maximum data rate:
7249 / 43869
Noise margin:
5.8 dB / 3.7 dB
Line attenuation:
38.5 dB
Signal attenuation:
24.9 dB / 38.5 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
38 kB Uploaded / 60 kB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-RG52
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-RG52
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
D0:57:94:D0:16:03
Software variant:
Boot loader:
0.48.8-sec
Log:
01:31:31, 22 Sep.
wl1:IGMP join received for group 224.0.1.187 on interface wl1
01:29:29, 22 Sep.
01:27:18, 22 Sep.
01:27:04, 22 Sep.
:HTTP UserAdmin login from 192.168.1.91 successfully
01:27:00, 22 Sep.
:HTTP UserBasic login from 192.168.1.91 successfully
01:26:40, 22 Sep.
:WAN DHCPv6 Client Prefix : 2a00:23c8:701:6c00::/56 (valid time = 315360000 / preferred time = 315360000)
01:26:39, 22 Sep.
wl0.2:WiFi security settings have been successfully saved
01:26:39, 22 Sep.
wl0.1:WiFi security settings have been successfully saved
01:26:39, 22 Sep.
wl1.1:WiFi security settings have been successfully saved
01:26:38, 22 Sep.
ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
01:26:38, 22 Sep.
ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
Message 4 of 5
01:26:38, 22 Sep.
01:26:32, 22 Sep.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
01:26:31, 22 Sep.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
01:26:31, 22 Sep.
ppp1:TR69 receiving InformResponse message
01:26:30, 22 Sep.
ppp1:TR69 event found : 4 VALUE CHANGE
01:26:30, 22 Sep.
ppp1:TR69 sending Inform message
01:26:29, 22 Sep.
01:26:28, 22 Sep.
01:26:28, 22 Sep.
ppp1:TR69 creating new session with ACS
01:26:26, 22 Sep.
01:26:25, 22 Sep.
01:26:25, 22 Sep.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
01:26:25, 22 Sep.
BR_LAN: Allocated prefix = 2a00:23c8:701:6c00::/64 (valid time = 2026291200 / preferred time = 2026291200)
01:26:25, 22 Sep.
BR_LAN: Allocated address = 2a00:23c8:701:6c00:d257:94ff:fed0:1603 (valid time = 2026291200 / preferred time = 2026291200)
01:26:25, 22 Sep.
01:26:25, 22 Sep.
ppp1: Allocated prefix = 2a00:23c8:701:6c01::/64 (valid time = 2026291200 / preferred time = 2026291200)
01:26:25, 22 Sep.
ppp1: Allocated prefix = 2a00:23c8:701:6c00::/56 (valid time = 2026291200 / preferred time = 2026291200)
01:26:25, 22 Sep.
ppp1: Allocated address = 2a00:23c8:701:6c01:d257:94ff:fed0:1601 (valid time = 2026291200 / preferred time = 2026291200)
01:26:25, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
BR_LAN:The LAN DHCPv6 Server is active
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
01:26:24, 22 Sep.
ppp1:WAN DHCPv6 Mode : Statefull
01:26:23, 22 Sep.
01:26:23, 22 Sep.
BR_LAN: Allocated prefix = 2a00:23c8:701:6c00::/64 (valid time = 180000000 / preferred time = 0)
01:26:23, 22 Sep.
ppp1: Allocated prefix = 2a00:23c8:701:6c01::/64 (valid time = 180000000 / preferred time = 0)
01:26:23, 22 Sep.
01:26:23, 22 Sep.
01:26:23, 22 Sep.
01:26:23, 22 Sep.
01:26:23, 22 Sep.
01:26:23, 22 Sep.
01:26:23, 22 Sep.
ppp1: Allocated prefix = 2a00:23c8:701:6c00::/56 (valid time = 180000000 / preferred time = 0)
Message 5 of 5
The router seems to flash purple and disconnects every 10 mins sometimes, usually at night, no service problems reported in my area
