Solved! Go to Solution.
This is posted about often and if you use search you will find many other posts. This is the DLM and normally the hub reconnects immediately at the same noise margin and connection speed. Unfortunately you cannot stop it apart from get third party router. It is more inconvenient than it is a line problem
If you are dropping that often then something wrong. Start your own thread and post some router stats
