CocoPops
Message 1 of 7
Connection dropping
Hi all, My connection has been dropping for awhile at night, 12-2am most nights, not really a big problem to be honest but its started happening during the day, Especially for the last week, 3 drops outs today, longest was around 40 minutes, I came home tonight to find my fiber running like a pile of ... saying i was getting 25 meg on a speedtest but couldnt load a youtube video, checked the hub, My noise margin / line attenuation  had flown right up, much higher than normal so i restart everything goes back to normal, any chance it could be the weather screwing with my line?
Worth getting an engineer out to have a look?
thanks 🙂
6 REPLIES 6
Message 2 of 7
Re: Connection dropping
can you post the stats from your router  the disconnections will probably increase your noise margin but should not increase your attenuation
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
CocoPops
Message 3 of 7
Just to double check, the stats in the tech log?
thanks for the help!
Message 4 of 7
if hh6 then advanced settings then technical log information
CocoPops
Message 5 of 7
Product name:
BT Hub 6A
Serial number:
+084319+NQ70415337
Firmware version:
SG4B1000B522
Firmware updated:
12-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 18 Minutes 38 Seconds
Data rate:
20.00 Mbps / 80.00 Mbps
Maximum data rate:
27194 / 113424
Noise margin:
10.2 dB / 15.3 dB
Line attenuation:
15.9 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
45153 MB Uploaded / 45429 MB Downloaded
Broadband username:
BT Wi-fi:
Active
2.4 GHz wireless network name:
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
Bloody thing went off again 20 minutes ago
Thanks for the reply again, much appreciated mate
Message 6 of 7
did you try quiet line test?
have you tried connecting to test socket with a filter to see if that improves your stability by eliminating your internal wiring and faceplate
CocoPops
Message 7 of 7
Tried the quiet line test, plugged straight into the master test socket, line seems fine, spoke to my mother about it, she said the phone line was crackling last night around 7 when she was on the phone, ended up using her mobile, Ill try the line later tonight.
Ive plugged into the test socket, ill see what happens, if the it goes stable, will i just replace the socket? Its the master socket 5c
Cheers for all the help imjolly, hopefully it sorts itself out, hahaha
