Saffiny
Message 1 of 7
Connection drops every single morning without fail for 6+ months
currently my internet is back to disconnecting every night it seems between the hours of 1am and 6am, and NEVER any other time, this was happening for months, i had openreach come around, they said they couldnt find anything and that it might be BT that was throttling me, he called BT and was also advised a "lift and shift" was not required and so i just stuck with the disconnecting every 24 hours (always once, and only once) now recently, i think a week ago, my connection actually managed to stay up for 6 days in a row, as you can believe this was a huge shock after never having my connection stay up for longer than a day. which i thought after 6 months it had been fixed, sadly its gone back to its usual disconnect every 24 hours
things ive tried were, quiet line test being left on when the connection dropped, which resulted in no abnormal sounds, a new router which still had disconnects, complete new wiring and cables, as you can see in the image my router will only ever "go down" every 2 weeks and im well aware that's when BT themselves forcefully reboot it remotely,
Here is what my log currently says
6 REPLIES 6
Saffiny
Message 2 of 7
Re: Connection drops every single morning without fail for 6+ months
03:24:23, 22 Sep.
wl0.2:WiFi security settings have been successfully saved
03:24:23, 22 Sep.
wl0.1:WiFi security settings have been successfully saved
03:24:23, 22 Sep.
wl1.1:WiFi security settings have been successfully saved
03:24:20, 22 Sep.
:WAN DHCPv6 Client Prefix : 2a00:23c7:c080:ba00::/56 (valid time = 315360000 / preferred time = 315360000)
03:24:16, 22 Sep.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
03:24:16, 22 Sep.
ppp1:TR69 sending SetParameterValuesResponse message
03:24:16, 22 Sep.
ppp1:TR69 receiving SetParameterValues message
03:24:16, 22 Sep.
ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
03:24:16, 22 Sep.
ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
03:24:16, 22 Sep.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
03:24:16, 22 Sep.
ppp1:TR69 receiving InformResponse message
03:24:16, 22 Sep.
ppp1:TR69 event found : 4 VALUE CHANGE
03:24:16, 22 Sep.
ppp1:TR69 event found : 2 PERIODIC
03:24:15, 22 Sep.
ppp1:TR69 sending Inform message
03:24:14, 22 Sep.
03:24:14, 22 Sep.
03:24:14, 22 Sep.
03:24:13, 22 Sep.
ppp1:TR69 creating new session with ACS
03:24:12, 22 Sep.
03:24:11, 22 Sep.
BR_LAN:LAN Router Advertisement Setting Updated : M_flag = 0, O_flag = 1
03:24:11, 22 Sep.
BR_LAN:The LAN DHCPv6 Server is active
03:24:11, 22 Sep.
BR_LAN:The LAN DHCPv6 Server is inactive
03:24:11, 22 Sep.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
03:24:11, 22 Sep.
BR_LAN: Allocated prefix = 2a00:23c7:c080:ba00::/64 (valid time = 2026291200 / preferred time = 2026291200)
03:24:11, 22 Sep.
BR_LAN: Allocated address = 2a00:23c7:c080:ba00:aa9a:93ff:fe43:2cff (valid time = 2026291200 / preferred time = 2026291200)
03:24:11, 22 Sep.
03:24:11, 22 Sep.
ppp1: Allocated prefix = 2a00:23c7:c080:ba01::/64 (valid time = 2026291200 / preferred time = 2026291200)
03:24:11, 22 Sep.
ppp1: Allocated prefix = 2a00:23c7:c080:ba00::/56 (valid time = 2026291200 / preferred time = 2026291200)
03:24:11, 22 Sep.
ppp1: Allocated address = 2a00:23c7:c080:ba01:aa9a:93ff:fe43:2cfd (valid time = 2026291200 / preferred time = 2026291200)
03:24:11, 22 Sep.
03:24:10, 22 Sep.
03:24:10, 22 Sep.
03:24:10, 22 Sep.
03:24:10, 22 Sep.
03:24:10, 22 Sep.
03:24:10, 22 Sep.
03:24:10, 22 Sep.
Saffiny
Message 3 of 7
03:24:10, 22 Sep.
03:24:10, 22 Sep.
03:24:10, 22 Sep.
03:24:10, 22 Sep.
03:24:10, 22 Sep.
03:24:10, 22 Sep.
ppp1:WAN DHCPv6 Mode : Statefull
03:24:10, 22 Sep.
03:24:10, 22 Sep.
03:24:09, 22 Sep.
03:24:09, 22 Sep.
03:24:09, 22 Sep.
03:24:08, 22 Sep.
03:24:08, 22 Sep.
03:24:08, 22 Sep.
03:24:08, 22 Sep.
03:24:08, 22 Sep.
BR_LAN: Allocated prefix = 2a00:23c7:c080:ba00::/64 (valid time = 240000000 / preferred time = 0)
03:24:08, 22 Sep.
ppp1: Allocated prefix = 2a00:23c7:c080:ba01::/64 (valid time = 240000000 / preferred time = 0)
03:24:08, 22 Sep.
03:24:08, 22 Sep.
03:24:07, 22 Sep.
03:24:07, 22 Sep.
ppp1:WAN Router Discovery Setting Updated : M_flag = 1, O_flag = 0
03:24:07, 22 Sep.
03:24:07, 22 Sep.
03:24:07, 22 Sep.
03:24:07, 22 Sep.
03:24:07, 22 Sep.
ppp1: Allocated prefix = 2a00:23c7:c080:ba00::/56 (valid time = 240000000 / preferred time = 0)
03:24:07, 22 Sep.
03:24:07, 22 Sep.
03:24:06, 22 Sep.
:WAN: SENSING AUTO VDSL
03:24:06, 22 Sep.
ppp1:New DYN ROUTE is added [81.139.57.100/32 gw 172.16.18.222]
03:24:06, 22 Sep.
ppp1:New DYN ROUTE is added [81.139.56.100/32 gw 172.16.18.222]
03:24:06, 22 Sep.
03:24:06, 22 Sep.
03:24:05, 22 Sep.
03:24:05, 22 Sep.
ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
03:24:05, 22 Sep.
03:24:05, 22 Sep.
03:24:05, 22 Sep.
03:24:05, 22 Sep.
Saffiny
Message 4 of 7
03:24:05, 22 Sep.
ppp1:PPP: PPP INFO
03:24:05, 22 Sep.
ppp:PPP: IPCP_NAK
03:24:05, 22 Sep.
ppp:PPP: CHAP_SUCCESS
03:24:05, 22 Sep.
ppp:PPP: CHAP_RESPONSE
03:24:05, 22 Sep.
ppp:PPP: LCP_GOOD_ACK
03:24:05, 22 Sep.
ppp:PPP: LCP_REQUEST
03:24:05, 22 Sep.
:PPPoE error: timeout
03:23:49, 22 Sep.
03:23:40, 22 Sep.
03:23:36, 22 Sep.
03:23:31, 22 Sep.
ptm0.101:VLAN VLAN_DATA connected
03:23:31, 22 Sep.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
03:23:31, 22 Sep.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
03:23:31, 22 Sep.
dsl:VDSL link Up: Down Rate=67482Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
03:23:16, 22 Sep.
wl0:A WiFi device <40:40:A7:B2:9B:C0> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
03:23:14, 22 Sep.
:TR69 connectivity to (pbthdm.bt.mo) has failed
03:23:14, 22 Sep.
:TR69 unable to send Inform message
03:23:14, 22 Sep.
03:23:14, 22 Sep.
03:23:12, 22 Sep.
03:23:10, 22 Sep.
:VLAN VLAN_DATA disconnected
03:23:09, 22 Sep.
wl0:Device <40:40:A7:B2:9B:C0> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
03:23:08, 22 Sep.
ppp1:The DYN ROUTE [81.139.57.100/32 gw 172.16.18.222] is deleted
03:23:08, 22 Sep.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
03:23:08, 22 Sep.
ppp1:The DYN ROUTE [81.139.56.100/32 gw 172.16.18.222] is deleted
03:23:08, 22 Sep.
03:23:08, 22 Sep.
ppp1:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
03:23:07, 22 Sep.
03:23:07, 22 Sep.
03:23:07, 22 Sep.
03:23:07, 22 Sep.
03:23:06, 22 Sep.
03:23:06, 22 Sep.
03:23:06, 22 Sep.
03:23:06, 22 Sep.
03:23:06, 22 Sep.
03:23:06, 22 Sep.
BR_LAN: Revoked prefix = 2a00:23c7:c080:ba00::/64 (valid time = 2026291200 / preferred time = 2026291200)
03:23:06, 22 Sep.
ppp1: Revoked prefix = 2a00:23c7:c080:ba01::/64 (valid time = 2026291200 / preferred time = 2026291200)
03:23:06, 22 Sep.
ppp1: Revoked prefix = 2a00:23c7:c080:ba00::/56 (valid time = 2026291200 / preferred time = 2026291200)
03:23:06, 22 Sep.
dsl:VDSL Link Down: duration was 80849 seconds
Message 5 of 7
can you post hub stats from advanced settings then technical log information
I am confused with connection drops every single day and my router will only ever 'go down' every 2 weeks
Saffiny
Message 6 of 7
I would love to know what this log is actually saying, also just to add, im well aware that power loads, and central heating can cause the router issues, but this happens at almost every time between 1am and 6am, for example last night it went down at 3:24am, tonight it might go down at 4am or 5am, it's completely random between 1 and 6, so it cannot be any issues related to central heating
Saffiny
Message 7 of 7
sorry was just getting round to making that post :P, was going to make sure i dumped as much info as i could
