wrutless
Message 11 of 19
Re: Connection is not the minimum guaranteed 67mb anymore
Hi there is no difference, not plugged in there anymore
Message 12 of 19
I was not expecting the connection speed necessarily to improve but I was hoping the max attainable would be higher as would the noise margin showing more scope for higher speed as the current figures suggest you are at max speed
Moderator
Moderator
Message 13 of 19
Hi @wrutless I called there but missed you, I'll try again this evening if that suits you?
Moderator
Moderator
Message 14 of 19
@wrutless I see that the engineer visit was cancelled as it was realised that your fault was connected to a service outage which has now been fixed. Can you post back and let me know if you're happy to close the case as resolved?
Neil
wrutless
Message 15 of 19
Hi Neil,
I'll check when I get home from work later and let you know.
Kind regards
Dean
Moderator
Moderator
Message 16 of 19
@wrutless no problem, I'll keep an eye out for your reply.
Moderator
Moderator
Message 17 of 19
@wrutless Hi Dean, did you get the chance to check your connection?
wrutless
Message 18 of 19
Hi neil I did try it last night and it still wasnt as quick as when I first took out the contract. It has gone faster though about 57 mb, but still about 10 short of the first few weeks of my contract.
I'll check it again tonight though
Kind regards
Dean
Message 19 of 19
can you post router stats again to compare with initial posted stats
