wrutless
Message 1 of 19
Connection is not the minimum guaranteed 67mb anymore
I have infinity 2, and when it was first installed I was getting a 67mb download speed. But now its more like 46mb-48mb which is way below the guaranteed on the order page.
I have noticed that my sync speed is the following
Downstream sync speed:
52.13 Mbps
Connection status:
BT Broadband /
BT Infinity /
BT Infinity 3 and 4 :
BT Infinity
 Firmware version:
SG4B1000B522
 Firmware updated:
01-Feb-2018
 Serial number:
+084316+NQ74577792
52.13 Mbps
 Upstream sync speed:
18.73 Mbps
 Network uptime:
11 Days, 17 Hours 34 Minutes
 System uptime:
11 Days, 17 Hours 37 Minutes
 BT Wi-fi status:
Active
I've done all the home checks. I haven't changed anything since the day the bloke set it all up.
Can a mod take over this problem for me? If you still do that, as i've had good service from the mod team before. The normal people I speak to on the phone are extremely unhelpful and I do not want to go through that again. I don't use a house phone but I did plug one in and there is no noise apart from the dial tone.
Dean
18 REPLIES 18
imjolly
Message 2 of 19
Re: Connection is not the minimum guaranteed 67mb anymore
Can you post the stats from advanced settings then technical log information
enter your phone number and post results remember delete number https://www.btwholesale.com/includes/adsl/adsl.htm
wrutless
Message 3 of 19
Serial number:
+084316+NQ74577792
Firmware version:
SG4B1000B522
Firmware updated:
01-Feb-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
11 Days, 19 Hours 19 Minutes 14 Seconds
Data rate:
18.73 Mbps / 52.13 Mbps
Maximum data rate:
22694 / 52481
Noise margin:
5.8 dB / 6.3 dB
Line attenuation:
14.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
25168 MB Uploaded / 205530 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-GHMP
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-GHMP
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
D8:D7:75:8A:90:49
Software variant:
Boot loader:
9.2.0
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)8063.4201955Available----
VDSL Range B (Impacted)8057.22017.243.7Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 3--1.5 to 5.5Available----
ADSL MaxUp to 2--1.5 to 4.5Available----
WBC Fixed Rate1----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date04-05-2018
imjolly
Message 4 of 19
have you tried using the test socket with a new filter to see if that improves your connection by eliminating the faceplate and your internal wiring
test socket shown by black arrow
PaddyB
Moderator
Moderator
Message 5 of 19
Hi @wrutless,
Have you had a chance to test the connection in the test socket? If so, have you noticed any difference?
If you're still experiencing issues with your connection, please post back.
PaddyB
wrutless
Message 6 of 19
Hi Paddy, yes it made little difference really the upload speed was slightly higher but that could have been because I tested it at a different time than when I performed the first test.
PaddyB
Moderator
Moderator
Message 7 of 19
Hi @wrutless,
Thank you for posting back. I'll be able to take a look at your connection and run a few checks on your line. Please can you send me in your details, using the "Contact The Mods" link found in my profile?
PaddyB
imjolly
Message 8 of 19
If connected to test socket can you post the new stats please
wrutless
Message 9 of 19
Hi PaddyB thanks I have just used the contact the mods link
imjolly
Message 10 of 19
If still in test socket can you post current stats from hub to see the difference
