I was not expecting the connection speed necessarily to improve but I was hoping the max attainable would be higher as would the noise margin showing more scope for higher speed as the current figures suggest you are at max speed
Hi @wrutless I called there but missed you, I'll try again this evening if that suits you?
@wrutless I see that the engineer visit was cancelled as it was realised that your fault was connected to a service outage which has now been fixed. Can you post back and let me know if you're happy to close the case as resolved?
Neil
@wrutless no problem, I'll keep an eye out for your reply.
@wrutless Hi Dean, did you get the chance to check your connection?
can you post router stats again to compare with initial posted stats
