Sneakyyz
Newbie
Message 1 of 3
Connection issues/lag on xbox
I’ve had bt for about a year now, and for the first 10 months it was perfect no lag, 50 Mbps and perfect ping, then my mates put a lock on the wifi from 10 until 7 and now it has been really laggy and around 10-20 mbps, it could either be a huge coincidence or it is because of that, I don’t know how to fix it any suggestions i can’t play anymore ???
2 REPLIES 2
Zombie
Expert
Message 2 of 3
Re: Connection issues/lag on xbox
Can your mate not take off the wifi schedule whilst you test it as that would rule it out if the problem is still there.  I take it you have no access to the router? Are you using a bt hub?
Sneakyyz
Newbie
Message 3 of 3
Oh sorry i was being unclear, i tool it off as soon as i realised but it’s still been really bad
