hernibles
Message 1 of 8
Connection renegotiates daily
Hello,
I have recently upgraded to Infinity from ADSL, about a month ago.
Where the ADSL connection was solid for weeks at a time I have noticed that more or less every day my router connection renegotiates.  The connection speeds change - randomly up or down - but never by much.  The timing of this is also random.
At the moment I am seeing 55228 down and 13108 up and it has been that way since approximately 1900 last night.  I am perfectly happy with that.
Is this to be expected?  I've only noticed because for example iPlayer is interrupted when the renegotiation happens, for 20 seconds or so.  I thought the connection was meant to stabilise after a couple of weeks.
David.
ps    I should add I am currently using a Draytek 2760n router, which I have had since ADSL.  It's fully firmware updated.  I will swap to the HH5 I have for a few days to see what happens!
7 REPLIES 7
Distinguished Guru
Message 2 of 8
Re: Connection renegotiates daily
Does the 2760n have line stats available which may shed some light on what is going on?
If not, I'll try again 🙂
hernibles
Message 3 of 8
This is all the info I can find:
hernibles
Message 4 of 8
Renegotiated tonight at 1845. Speed now 55548 / 13104
Distinguished Guru
Message 5 of 8
Is there some electrical device coming on at this time which could be causing some interference, e.g. central heating?
hernibles
Message 6 of 8
I think I am making some progress here.  Connection dropped in front of my eyes, at the moment a TODO backup started at my PC, saving to a QNAP NAS that I have.
Looking at DRAYTEK support forums it seems they can be somehow sensitive to inappropriate DNS selection, causing VDSL2 to drop momentarily.
QNAP was on a locally fixed IP address but with a utterly spurious DNS entry (layer 8 problem on my side)
Have now fixed the IP through "binding" to it's MAC address at the router, so router is in complete control.
I am 51% optimistic of a good outcome.  WIll see in the coming days when my backup triggers.
Tags (1)
hernibles
Message 7 of 8
Re: Connection renegotiates daily [Draytek 2760n; solved I believe]
Hello again,
It was recommended on Draytek forums that I upgrade the firmware to a version that specifically supports vectoring.  I did that and the connection has been rock solid ever since.
From what I have read BT vectoring enhancements have not yet been rolled out............but maybe this is incorrect.  Can anybody comment on this?
David
dfenceman
Expert
Message 8 of 8
@hernibles wrote:
Hello again,
David
Not according to this :-
http://www.increasebroadbandspeed.co.uk/2014/vectoring-crosstalk-crisis
Best regards,
dfenceman
