nblackburn
Message 1 of 12
Connection restarts every 10 days exactly
For the last few months my connection is getting restarted every 10 days exactly. I assume it must be my router triggering this (HH6) and not DLM? There's nothing obvious in its event log though.
My connection has been banded for well over a year but if it was DLM doing the restart it would wait until the middle of the night?
Thanks.
11 REPLIES 11
imjolly
Message 2 of 12
Re: Connection restarts every 10 days exactly
Normally the posts are about 14 day restarts but a few were getting it every 10 days. Having had the 14 day reset it always reconnected immediately and always at same speed after as before reset Only real solution I think is a 3rd party router
Keith_Beddoe
Message 3 of 12
Thanks.
Its BTs WAN Management Protocol (also called TR-069) which allows the Auto-Configuration Server (ACS) to perform auto-configuration, provision, collection, and diagnostics , and send them to BT. That is a built in function of the BT Home Hubs.
You may see a reference to TR-069 or ACS, in the event log if you filter the results.
nblackburn
Message 4 of 12
I was wondering why my search for '10 days' didn't throw up any results related to this! It probably started happening with the May firmware update.
I do get ACS and TR69 references in the event log but not around the time of the restart.
imjolly
Message 5 of 12
The 14 day reset has been on the go far longer than the may update
Message 6 of 12
Is it 10 days or 14 days for the restart?
Check your your homehub from the HH6 manager at 10 / 14 day intervals. There’s no need to go into advanced settings. When you see a restart as seen in the number of days of connection time, then look into advanced settings event logs
For example, someone here has a HH6 which is due to reset Thursday midnight. There’s nothing to be done as the connection speeds remain roughly the same, after the reset.
From past experience, if your hub is resetting in the day, at 7-00pm, after 14 days,, say.......it will eventually change to midnight after an unscheduled restart .  You have to wait.....!
nblackburn
Message 7 of 12
Mine is 10 days and has only started doing it in the last few months. It was fine before, used to get to 20+ days. I don't mind it restarting, but it does it during the day which can be annoying.
nblackburn
Message 8 of 12
10 days for me. The restart is always 10 days to the second so it will do it during the day, it's never changed to midnight having done it several times.
My speed is banded so it never changes anyway.
Message 9 of 12
Since recontracting to the new BT Plus state of things, there have been various restarts at random times, presumably to optimise the speeds, snr margins etc. Eventually the restart has settled down to a 14 day cycle, now at midnight on the 14th day. Previously the restart time had been at 7-00 pm, advancing by 20 mins each period...so eventually it would have ended up at midnight, some time next year. However by a stroke of fortune, somehow the system intervened to set the restart time to midnight.
If you know the exact time "to the dot" when you hub restarts in the 10 day cycle, then wait for about 20 -30 mins after that time, then open up the Hub Manager. In advanced settings you then the pinpoint that time in the event logs, to see what has happened.
pompey1898
Recognised Expert
Message 10 of 12
Mine resets every one or two days at totally random times, mainly during the hours of darkness.
Fortunately the speeds only vary by a few Mbps and since my problems of May, and the fix by OR on 11-6, at speeds which I can't complain about.
