gazza49er
Message 1 of 19
Constant Disconnects
Hi, i repoted this fault last week along with slow speed after multiple disconnects and  i had an engineer come to check my line on the 9th and everything was ok. Did a speed test on the BT site and it reported a problem outside my house, saturday i noticed an engineer outside and my broadband and land line went off as i guess he was working on it. When it came back my speed was back to normal and it stayed connected for 2 days but tonight the 13th it has disconnected 3 times in 4 hours again. This is getting really annoying can anyone help?
Message 2 of 19
Re: Constant Disconnects
do you have noise on landline  dial 17070 option 2  should be silent and best with corded phone
post hub stats  if hh6 then advanced settings then technical log information
gazza49er
Message 3 of 19
Hi,  there was noise on the line when i reported this but when engineer came friday it was all clear and has been since.
This is the technical log info for the Homehub6:
Product name:
BT Hub 6A
Serial number:
+084319+NQ81181256
Firmware version:
SG4B1000B540
Firmware updated:
14-Aug-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 5 Hours 9 Minutes 39 Seconds
Data rate:
20.00 Mbps / 80.00 Mbps
Maximum data rate:
30470 / 94300
Noise margin:
12.4 dB / 9.1 dB
Line attenuation:
12.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
56 MB Uploaded / 985 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-C3PX
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-C3PX
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
AC:3B:77:14:62:23
Software variant:
Boot loader:
9.2.0
Hope this is what you wanted.
Moderator
Moderator
Message 4 of 19
Product name:
BT Hub 6A
Serial number:
+084319+NQ81181256
Firmware version:
SG4B1000B540
Firmware updated:
14-Aug-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
Data rate:
Maximum data rate:
30470 / 94300
Noise margin:
12.4 dB / 9.1 dB
Line attenuation:
12.2 dB
Signal attenuation: VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Broadband username:
BT Wi-fi:
Active
BTHub6-C3PX
Smart (Channel 1)
BTHub6-C3PX
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
AC:3B:77:14:62:23
Software variant:
Boot loader:
9.2.0
That's what @imjolly is after for sure @gazza49er,
You must be very close to the fibre cabinet as your line has good potential.  Others should be along shortly to offer you further advice.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
gazza49er
Message 5 of 19
Can anyone help?    It stayed stable for 2 weeks but tonight its started disconnecting again.  I was worried about this when going to fibre as i read somewhere that our exchange was over subscribed and when it gets busy will chuck people off, is this right?  I feel like going back to my old normal braodband which was at least stable.
Distinguished Guru
Distinguished Guru
Message 6 of 19
I don't know where you read that but it is clearly rubbish and does not happen.
Did you check the line again as requested?
gazza49er
Message 7 of 19
Yes the line checks all come back ok,  ive had disconnects every night this week and as my main hobby in semi pro sim racing i cannot take part in a lot of the events as i cant trust the broadband to stay up.  What else can i do?
Message 8 of 19
When you said the line check were fine, was that the quiet line test, or just the BT line test?
Communityhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
gazza49er
Message 9 of 19
Both and an engineer came and tested it too. Tonight it has disconnected twice already, 5.40pm and 7.50pm
Distinguished Guru
Distinguished Guru
Message 10 of 19
Do you still get drop outs if connected to the test socket with filter?
