gazza49er
Message 11 of 19
Re: Constant Disconnects
I don’t know, the engineer fitted the latest faceplate, I don’t have any filters anymore.
Sage
Sage
Message 12 of 19
Wouldn't be the first time a fceplate has been faulty...
You could try a factory reset of the hub by holding in the recessed button for about 20 secs until the lights flash.
gazza49er
Message 13 of 19
The reset button wont even work!  Held it in for well over 20 secs and nothing.
Message 14 of 19
Then the home hub is broken.
gazza49er
Message 15 of 19
So how do i go about getting a replacement Hub?
Message 16 of 19
Ring customer services. If you are still in a contract, it should be replaced for free, otherwise you would have to pay for it, or agree to a new contract.
The alternative is to use your own modem/router instead.
gazza49er
Message 17 of 19
Can i get a moderator to look in to this for me? I managed to factory reset the Hub using the browser but still disconnecting multiple times a day.  I seem to be getting nowhere.
Sage
Sage
Message 18 of 19
You cannot factory reset by any browser only by physically using the recessed button.
Are you still in contract? If so ring in and ask for a replacement.
gazza49er
Message 19 of 19
Are you sure? If I log into the hub through browser there’s an option to factory reset.
