KieronW
Message 31 of 47
Re: Constant connection drops and low speeds.
I'm going to try that, hopefully I'll find the right channel and the internet will start being more stable. This is annoying because we was on BT for years without issue and lately there's been non stop problems.
I'm going to try each channel, would it be worth switching back to 2GHz? Or does that not really matter.
KieronW
Message 32 of 47
Here's an update, I've tried wireless every channel on both frequencies, tried wired and wireless and still the same issue. None of our wireless devices are able to have a stable connection with our router, it's only worth using wired connections which isn't what we signed up for with BT so we're looking at ending our contract if this doesn't show signs of working soon as we're clearly not getting the service we was sold and it seems this won't be fixed any time soon. I've not been able to watch videos of my phone or play my Xbox properly for months without non stop connection drops and lag spikes, this happens on every device in the house. We get a wireless drop about every 5 minutes, we're really getting frustrated by this as we're running out of ideas, whatever the issue is is a new issue as we was with BT for years without issue but now it's every 5 minutes. We was sent a new hub as a replacement to rule out the hub and the hub was a BT home hub 3 which is ancient. We feel like we're getting nowhere right now we've already had 2 engineers visit too. Frustrating.
Message 33 of 47
Can you please confirm that there are no issues with Ethernet connected devices, only wireless devices?
Which home hub are you actually using at the moment?
KieronW
Message 34 of 47
It's a BT homehub 6 I think, it's the latest of the hubs.
Can't really answer that as we don't need ethernet cable devices long enough to be able to notice a difference, the lag spikes happen every 30 minutes or so.
My younger brother recieved some Xbox games over Christmas and hasn't been able to play them yet since he keeps getting kicked off, so we're all getting quite frustrated in this house with the internet at the moment.
I'll tried all channels and fiddled around with the frequencies and nothing has changed.
Message 35 of 47
Its always better to avoid wireless connections, and use broadband extenders instead, if you cannot run a direct Ethernet cable.
https://www.shop.bt.com/mini-sites/connected-home/broadband-extenders
The home hub 6 only has a choice of three wireless channels on 2GHz, out of 13, so its not very good in that respect.
I would not bother with 5G, as it only has limited range.
My only other suggestion at this time, would be to try a 3rd party router which allows all channels to be selected, and may actually give a more reliable wireless connection.
Prices start at £30, and are available locally or online. You can normally return them if it does not help.
Message 36 of 47
the 5ghz on my HH6 works well but just depends on how far your device is away from the hh6
did you also change the wireless mode from 1 to either 2 or 3 to see if that helps
KieronW
Message 37 of 47
I'm not 100% sure what number of hub I have, I just know it's currently the latest one as we've only had it for a couple of months. On average we are getting lag spikes on each device at around every 10 minutes or so, sometimes they last for a few seconds and sometimes they will take the device offline completely for a while.
How good are the BT extenders? curious as to how they can help give a stable connection when they are wireless themselves. I don't think we're going to pay extra for any devices though as we're already paying £65 per month for the service as it is.
Message 38 of 47
your previous post said you had latest hub which is the HH6
did you split the 2.4/5ghz networks to see if that helped
KieronW
Message 39 of 47
Don't think i've changed wireless modes before, only channels and frequencies, i'll have a look. Thanks
KieronW
Message 40 of 47
Yeah if HH6 is the latest then that's we have right now.
I've played around with the frequencies, didn't make any real difference unfortunately.
