Pevadartel
Message 11 of 23
Re: Constant intermittent disconnects Infinity
 I contact the BT helpdesk for that? Anything specific I would need to ask them as all other engineers never found any line issues or stability issues.... What is the chance I simply have 2 dodgy routers?
Pevadartel
Message 12 of 23
I have restarted it again and back to old sync speeds. However I noticed that when I tried to open the homehub dashboard it took a long(er) time to come up. Not sure if that would point at anything?
Moderator
Moderator
Message 13 of 23
Hi @Pevadartel,
Thank you for posting back and for taking my call earlier. I'm sorry to see that the instability has returned.
I'm running a few checks on your line and I'll give you a call in a few minutes.
PaddyB
Pevadartel
Message 14 of 23
OK, will await your call. For info, just to be able to either count out or count in the router I just bought a TP-Link one I am planning to put in place of the homehub to see if that solves the issue but I will await your call before doing that
Pevadartel
Message 15 of 23
Info/update:
New router has the same issue. Had a few disconnects already and the latest one resulted in the following:
102 dB attenuation upstream whilst the downstream one seems to be OK? Is this something that looks familiar and points to a certain/specific line error by chance?
Pevadartel
Message 16 of 23
Well downstream was showing as round 6-7 dB before I believe
Moderator
Moderator
Message 17 of 23
Hi @Pevadartel,
Thanks for getting back to us. As you know, @PaddyB is out of office today. I've sent him an email so he knows that you have been in touch.
DanielS
Pevadartel
Message 18 of 23
I have not seen or heard from an OpenReach engineer (they might still come.. ??)? In the meantime my connections seems to have been locked down to a slower sync:?
Data rate:
8.50 Mbps / 32.40 Mbps
Maximum data rate:
17721 / 43615
Noise margin:
13.1 dB / 9.4 dB
Line attenuation:
17.7 dB
Message 19 of 23
if you have connection stability problems then it is normal for DLM to increase noise margin and reduce speed
Pevadartel
Message 20 of 23
Understand that, putting my ongoing saga in here so the community and moderators keep appraised of what is happening. I was told an OpenReach engineer would be coming today between 8am and 1pm so assuming/hoping that will still happen (even if it is after 1pm now)
