FirstOne
Message 1 of 5
Could someone explain this ? bad company practice
I got a contract with BT for Infinity 1 with a new line install, everything was fine i was getting the top speed offered by the package witch was 52 Mb/s. After a couple of months i received an offer to upgrade to Infinity 2 (up to 72 Mb/s) witch i did  but the top download speed was 39 Mb/s. Now i let 10 days pass thinking it would take sometime to adjust but nothing change i opened and issue and was told that everything was fine and i was getting the minimum speed guaranteed witch is 35 Mb/s and this got my contract renewed by 12 months to end PAYING MORE FOR LESS. After a month i decided to downgrade back to Infinity 1 in hopes to at least get back to my speed of 52 Mb/s but without any luck. Now i'm getting 35-39 Mb/s with a new 12 months contract and i pay more than my first contract with Infinity 1. Is this BT company practice and scamming people ?
4 REPLIES 4
Message 2 of 5
Re: Could someone explain this ? bad company practice
Can you post back the results of this checker editing out your phone number
http://www.dslchecker.bt.com/
FirstOne
Message 3 of 5
youre as usefull as the bt staff !
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  HighLowHighLow
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
Premise environment
Status
VDSL Range A (Clean)53.339.813.48.735Available----Yes--
VDSL Range B (Impacted)42.32511.25.720Available----Yes--
FTTP on Demand33030--Available--------
WBC ADSL 2+Up to 4.5--3.5 to 5.5Available--------
ADSL MaxUp to 3--2 to 6Available--------
WBC Fixed Rate1----Available--------
VDSL Multicast------Available--------
ADSL Multicast------Available--------
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date18-05-2017
Distinguished Guru
Message 4 of 5
I assume you realise @John 46 is a customer of BT and not an employee?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 5 of 5
Your line will not support Infinity 2 speeds as you are too far away from the cabinet. You are within the estimated speed range for Range A.
Did you check what you were likely to get, before you agreed to upgrade?
Can you please post the connection speed reported by your home hub?
Please can you provide http://speedtest.btwholesale.com/  results including the further diagnostics page?
This must be done using a computer connected to the home hub, using an Ethernet cable.
