Newbie
Message 1 of 4
Creating two network SSID
How do I setup two indivudal networks using a BT Smart Hub 2?
There isnt a dual band option on here.
3 REPLIES 3
Sage
Message 2 of 4
Re: Creating two network SSID
You can't. That is a limitation of the Smart Hub 2.
Message 3 of 4
There is a workaround but it will cost you in the region of £30 so maybe not worth it.
Simply disable 2.4GHz on the hub Wi-Fi and connect something like the BT Homehotspot 600 to the hub to provide a  2.4Ghz carrier with it's own SSID
https://www.bt.com/help/user-guides/broadband-and-wi-fi-devices/wi-fi-and-home-networking/wi-fi-home...
Sage
Message 4 of 4
Or be sensible and get a suitable third party router.
