SteveBB
Message 1 of 6
Currently syncing at 34541Kbps, any point upgrading to BT Infinity Plus?
I'm currently on the old BT Infinity 1, would upgrading to Plus improve my speed or is this just what I can get? I'd definitely like a bit more speed and Virgin isn't in my area.
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Currently syncing at 34541Kbps, any point upgrading to BT Infinity Plus?
In order to find out what connection speed, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
also
If you are using the BT Smart hub please can you post your connection stats by, Open a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click Advanced Settings’ and then ‘Technical log’
SteveBB
Message 3 of 6
I'm using a Billion router, haven't used a BT one in ages, I have a super old one in a cupboard somewhere.
Line Rate - Upstream (Kbps) 7687
Line Rate - Downstream (Kbps) 34541
Tags (1)
Keith_Beddoe
Message 4 of 6
Based on what you have posted, there is no point in upgrading, as your line cannot support a higher speed.
imjolly
Message 5 of 6
I agree keep your money
NeilO
Moderator
Moderator
Message 6 of 6
@SteveBB  I agree with what has been said about the speed, as you have Fibre broadband already you wouldn't see a speed improvement however with the BT Plus service there are other benefits such as the complete wifi guarantee and our keep connected promise should your broadband ever become faulty.
This helpful article and video may help you choose if BT Plus is the right option for you.
