Message 1 of 3
DLM/Profile Reset?
Hi all,
Just wondering if this was the best speed I can achieve on the line or if I need to get a DLM/profile reset?
Grant
2 REPLIES 2
Message 2 of 3
Re: DLM/Profile Reset?
There's nothing in the stats to suggest a DLM reset will change anything.
Message 3 of 3
@pippincp thanks - I did think that would be the case, but thought it was worth an ask! Cheers
