evansnp
Message 1 of 7
DLM intervention, how long is long?
I posted an issue back in October 2018 about my profile being stuck at 74000 after an 'upgrade' to BT+.  I was told that a stable line would see DLM kick in, and remove interleave / banding etc.  Well, it has now been 75 days of rock solid uptime and my line has nto changed at all:
DSLAM type / SW version:	BDCM:0xa48c (164.140) / v0xa48c
Modem/router firmware:  	AnnexA version - A2pv6F039v.d26q_rc1a
DSL mode:               	VDSL2 Profile 17a
Status:                 	Showtime
Uptime:                 	75 days 5 hours 1 min 15 sec
Resyncs:                	0 (since 08 Feb 2019 11:35:06)
				Downstream	Upstream
Line attenuation (dB):  	14.3		0.0
Signal attenuation (dB):	Not monitored
Max:    Upstream rate = 30107 Kbps, Downstream rate = 88273 Kbps
Connection speed (kbps):	74000		19999
SNR margin (dB):        	9.5		15.5
Power (dBm):            	13.7		5.5
Interleave depth:       	16		1
INP:                    	49.00		0
G.INP:                  	Enabled		Not enabled
Vectoring status:       	1 (VECT_FULL)
RSCorr/RS (%):          	0.0807		0.0362
RSUnCorr/RS (%):        	0.0000		0.0000
ES/hour:                	0		0
Surely, something should have happened by now?
6 REPLIES 6
Message 2 of 7
Re: DLM intervention, how long is long?
Is the 75 days router uptime or line uptime?
I ask for 2 reasons, one, when I used a TP Link the uptime was router powered up time not connection time and secondly, your screenshot reports 0 resyncs but only since today at 11.35 which seems odd.
evansnp
Message 3 of 7
Line uptime. router uptime is 79 days
Moderator
Moderator
Message 4 of 7
Hi @evansnp We will be happy to see if we can manage to get your speed to increase and I've sent you a Private message explaining how you can contact the forum moderation team.
Check here https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 5 of 7
Hi @evansnp
Thanks for taking my call yesterday, I've raised a case on your account and as soon as I have an update I'll be back in touch as discussed.
Cheers
Stuart
Community ModeratorStuartH
Kudos”
Moderator
Moderator
Message 6 of 7
Hi @evansnp
Tried calling on your mobile, sorry I missed you.
Having ran some tests I can see the speed looks like it has recovered, please test and post back to let me know if this has benn resolved.
Cheers
Stuart
Kudos”
evansnp
Message 7 of 7
Hi Stuart;  Speed has indeed been restored, thanks very much!
My only question is that interleave is still 16, whereas I thought that it would be zero (Fastpath).
PS: Sorry I missed your call, I was on a conf call  :-(
