Bobsta
Message 1 of 3
DLM reset after resolving internal wiring fault
Hi folks,
I noticed a few months ago that my parents’ FTTC service was a bit unstable. Looking in the router logs there were frequent resyncs and the sync was quite a bit lower than I’d expect given their proximity to their cabinet.
A few weeks ago I swapped out the filters used in the house and tidied up some old extension wiring. Now the connection is very stable and their Hub (6A) reports a max sync rate of ~23Mbps up / 69Mbps down - but is stuck syncing at 15Mbps up, 32Mbps down.
My assumption is that the internal wiring has been dodgy ever since they switched to FTTC a few years ago, so DLM has ratcheted the rate right down.
Could a moderator advise how we can get it reset please?
Stats excerpt from Hub 6A:
Data rate: 15.00 Mbps / 32.40 Mbps
Maximum data rate: 22949 / 68715
Noise margin: 9.7 dB / 16.7 dB
Line attenuation: 16.3 dB
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Thanks.
2 REPLIES 2
licquorice
Message 2 of 3
Re: DLM reset after resolving internal wiring fault
Just leave  the connection in a stable condition and DLM will do its stuff and increase speed.
imjolly
Message 3 of 3
You should have posted the full stats from the hub not just abbreviated and missing off the connection time
