Message 51 of 72
Re: DLM reset
Have you got some Openreach documentaion to back this up?
Message 52 of 72
Re: DLM reset
There's not a lot publicly available, but there have been discussions on broadband forums suggesting that banding needs to be removed by a DLM reset as it doesn't remove itself automatically.
Message 53 of 72
Re: DLM reset
Discussions on forums are not facts or proof I'm afraid.
Moderator
Moderator
Message 54 of 72
Re: DLM reset
@William_Grimsley I can confirm that what you have posted is incorrect. Banding is still removed automatically by DLM if your line is stable. Occasionally this may not work correctly and a manual reset is needed.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Message 55 of 72
Re: DLM reset
Apologies. 🙂
Message 56 of 72
Re: DLM reset
Can I have a manual reset please?
smf22
Recognised Expert
Message 57 of 72
Re: DLM reset
I'll take one as well if they're being given out Smiley Very Happy
Moderator
Moderator
Message 58 of 72
Re: DLM reset
@smf22 and @licquorice Sorry guys they're not being handed out. The reset is done when an Openreach engineer visits after you've reported a fault.
Kudos”Kudos”
Message 59 of 72
Re: DLM reset
And there's the catch22. The fault that caused the banding back in March fixed itself.
smf22
Recognised Expert
Message 60 of 72
Re: DLM reset
Mine took a little more effort of cutting down a tree line, but ultimately the "fault" is now gone. I've had the line not drop for as long as 5 weeks and no DLM reset was forthcoming. Stuck rigid at 34999. But I'm not complaining. Many would love to get as much as this.
