Paul1415
Message 1 of 8
Hi, we've recently had a line fault repeared by an engineer along with a DLM reset because the fault completely ruined the speed. I have a screenshot of what our speeds where a couple weeks ago before this fault occured and what they are currently. We had the 3db noise margin active, will this reactive itself again because it gave us a 10mb increase which is really good for this household.
AfterAfterBeforeBefore
7 REPLIES 7
pippincp
Sage
Message 2 of 8
Re: DLM
Yes, if needed G.IMP will reactivate, takes about 10 days from DLM reset.
Paul1415
Message 3 of 8
Re: DLM
ok what about the maximum data rate, will that increase too??
licquorice
Message 4 of 8
Re: DLM
Yes, but its academic as it is the actual data rate that matters. The maximum data rate is just a theoretical figure taking in to account your line parameters at the time. Its low now because G.Inp and 3dB margin haven't kicked in yet.
Paul1415
Message 5 of 8
Re: DLM
ok thanks. Is there any specific reason why the line attention decreased?
licquorice
Message 6 of 8
Re: DLM
By 0.2dB?
pippincp
Sage
Message 7 of 8
Re: DLM
A 0.2dB negligable attenuation decrease can be put down to the temperature of the copper wire at the time of measurement.
https://www.quora.com/How-does-the-conductivity-of-copper-vary-with-temperature
Paul1415
Message 8 of 8
Re: DLM
Ah. Thanks for the help guys. Appriciated.
