tpatel
Message 1 of 12
DSL Checker Stats Changed
The stats on the dsl checker for VDSL changed and the low downstream line rate has gone up as well as downstream handback.
How come that is the case?
Old
New
11 REPLIES 11
Techwizz
Message 2 of 12
Re: DSL Checker Stats Changed
Sometimes they do, mine has repeatedly, even though they're still unrealistically low.
pompey1898
Recognised Expert
Message 3 of 12
Hi @tpatel,
They are updated when speeds in an area change, up or down.
tpatel
Message 4 of 12
Why do speeds in an area change?
pompey1898
Recognised Expert
Message 5 of 12
@tpatel,
For all manor of reasons, eg  new technology, crosstalk, to name but one in each direction.
If you require a more detailed list then you will have to wait for a guru or mod.
tpatel
Message 6 of 12
Can you tag a guru or mod for me?
pompey1898
Recognised Expert
Message 7 of 12
Sorry, no.  I have no more rights than you.
pippincp
Sage
Message 8 of 12
As the temperature drops the conductivity of copper increases slightly. e.g. a copper wire with 500ohms resistance at 20 deg C would have a resistance of 630ohms at 80 deg c.
tpatel
Message 9 of 12
So if Temperature colder and resistance is higher connections speeds increase? Like in Winter
pippincp
Sage
Message 10 of 12
Lower temperature = less resistance and increased conductivity. You won't see a large leap in speeds.
